Prins present at fair in Istanbul together with its distribu
Διαβάσατε κάτι ενδιαφέρον για το υγραέριο; Μοιραστείτε το!
Δημοσίευσηαπό dathens » Τρί 29 Μαρ, 2011 10:21
Last week on the 4th LPG, CNG, LNG / GAS TURKEY Exhibition in Istanbul the latest Prins products were displayed for all the visitors of the stand. The customers could see 2 converted cars with the latest technology of Prins inside and also some demo parts of the completely new VSI- 2.0 and Direct LiquiMax were displayed. This all took place on the stand of Ipragaz, the official distributor of Prins products in Turkey.
The entire new VSI- 2.0 system is an evolution of the proven VSI technology. The system is equipped with a modern fuel switch with fully adjustable LED colours, so the switch can be matched with all dashboard colours. The system is applicable for all EURO-5 engines. The system can even achieve an even better fuel economy and lower emissions.
The Direct LiquiMax system can be used on (Lean-burn) Direct Injection engines. Direct Injection means that the fuel is injected under high pressure [20-200 bar] directly into the cylinder instead of injecting the fuel into the manifold (port injection). This allows for controlling combustion and emissions much more precisely. The use of LPG as an alternative fuel on DI engines could significantly enhance the DI technology benefits in terms of fuel efficiency and lower emissions especially in regards to CO2 and particles reductions.
On the exhibition stand was a Mercedes and Hummer displayed. Below you will find some pictures of the stand.
Re: Prins present at fair in Istanbul together with its dist
Δημοσίευσηαπό astragjtg » Τρί 29 Μαρ, 2011 16:36
dathens έγραψε:Εικόνα
Το ειχα πετυχει παλιότερα σερφαροντας.
Αντε και στα δικα μας τα μερη καμια LPG-έκθεση....(μαλλον θα αργησει..)
Επιστροφή στο Άρθρα στον τύπο
