ValveCare is unique because the additive dosage is based on engine load and actual fuel consumption and the distribution of the fluid is 100% equal over all cylinders. Consequently, the engine is always protected by the appropriate amount of additive, even in the case of turbocharged engines. Since the correct amount of additive is injected at all times, the additive consumption is very economical.
Πιστεύω οτι είναι παρόμοιο με το valve protector kit (το οποίο όμως συνδέεται τόσο σε συστήματα αέριου όσο και υγρού ψεκασμού, ανεξαρτήτως κατασκευαστή).
